It is currently Sun May 18, 2025 8:29 pm
PostPosted: Wed Oct 26, 2005 3:17 am
Can anyone recommend a good source for tempered spring steel for a fox-type bender? McMaster has 6x50x.015 for about $20 each, which isn't terrible but I was hoping I could find them for less.
Lots of places seem to carry the "Shim in a Can," but not so many seem to stock the blue tempered steel version, which they do make. I don't need stainless as I wrap my sides in aluminum foil.
I want tempered spring steel so they don't hold the shape of the bender. I've been using cheapo hardware store steel which has worked fine mostly, but it holds the shape and it's a pain lining up the side in the bender between the curved slats. The last time I bent sides, I had one buckle on me and wreck the side because of all the fidgeting around I had to do to get everything lined up (read about it here on my blog).
PostPosted: Wed Oct 26, 2005 3:32 am
Check with John at Blues Creek here on OLF
That is where I bought my bender. I know he has slats, but I don't know the
price.
Andy
PostPosted: Wed Oct 26, 2005 3:46 am
   HI
    The $20 a piece is the price. You won't find what you need any cheaper. Spring steel is high temper metal with a high iron content. Here are the advatages and disavatages of the different slats
STAINLESS STEEL
    Well it is stainless. I use a tempered stainless but it still isn't as hard as the spring steel. The Stainless will have a tendency to take a memory stress bend. This isn't a big deal but some like the slats straight.
     I personally use the stainless on standard and spring steel on the cutaway. Storing the stainless in a coil will help to get the ripples out.
    SPRING STEEL
     This stuff is hard and will stay straight. Very strong but it will stain the wood. DON'T USE ALUMINIUM FOIL !. I see this recommended alot. The alum is sometimes reactive to resins in diffrent woods. If you use it you will get burned on day. I have seen it turn Koa Green   Mohagany Brownish grey   and maple purple.
    You can't tell when it will do it . I use KRAFT PAPER as a barrier. This is great stuff as it is wood celouse and non reactive. It is also a great water carrier when you have highly figured woods.
   I hope I helped
Good luck
john hall
Blues Creek Guitars
PostPosted: Wed Oct 26, 2005 4:21 am
I can vouch for the koa turning green
PostPosted: Wed Oct 26, 2005 4:28 am
Funny, I've never had an issue with aluminum foil and wood, and I've bent bunches of different stuff. I too use springsteel slats - .01" though. I've never had luck using the kraft paper. The contaminated water that touches the springsteel finds it's way back in there and stains the wood too.
But I'm color blind so who knows if I've stained wood or not!
PostPosted: Wed Oct 26, 2005 4:31 am
Thanks for the tips, John. Is Kraft paper the same thing as the baking paper you can get at the grocery store? Do you wrap the sides, or just layer it in with the blankets and slats?
PostPosted: Wed Oct 26, 2005 4:32 am
if you know anyone else who needs slats the 0.010 tempered spring steel is available from enco in 25' lengths for about $85.
PostPosted: Wed Oct 26, 2005 4:36 am
I too have turned Koa green using Aluminum foil. I'm sure that the baking paper would work just fine. I use a few wraps of a end roll I got from our local newspaper, works great. It seems to be the only thing our local newspaper is good for. Their spelling is worse than mine!Jim_W38651.5673611111
PostPosted: Wed Oct 26, 2005 7:33 am
Is this the same paper shown on Factory Fridays? Bob Taylor seems to have found with his equipment and using paper that they don't worry about spritzing the wood. Maybe we should all buy equipment like his . I,too, am looking for steel for a bender and this is the first time I have heard using steel without being stainless. But I guess the idea of using paper makes the difference. What is the best thickness for bending? Does anybody use the perferated metal like Mike Doolin? I liked his bender on his web site.
PostPosted: Wed Oct 26, 2005 7:50 am
Don,
where did you get your .01 spring steel? I sure could use a few.
Craig
PostPosted: Wed Oct 26, 2005 7:55 am
I want my kraft paper, paper thin
PostPosted: Wed Oct 26, 2005 7:57 am
Craig,
I bought a roll of it from McMaster-Carr many moons ago.
PostPosted: Wed Oct 26, 2005 8:29 am
I went ahead and ordered the .015. I've heard anywhere from .010 to .020, so I split the difference.
Here's the page I ordered from with the different thicknesses available. (McMaster # 9503k21)
PostPosted: Wed Oct 26, 2005 9:40 am
anyone know a canadian source? I have tried all the Steel places with in a 6 hour drive and no one carries it.
PostPosted: Wed Oct 26, 2005 11:00 am
stupid question john, where do you get that paper? and is that the paper that Taylor Guitars use?
PostPosted: Wed Oct 26, 2005 1:06 pm
[QUOTE=Brock Poling]
I can vouch for the koa turning green [/QUOTE]
oh, man, that would turn ME green chmood38651.9228356481
PostPosted: Wed Oct 26, 2005 1:09 pm
I believe Kraft paper is what they make the big paper grocery bags from.
PostPosted: Wed Oct 26, 2005 9:23 pm
Office Depot has it.
http://www.officedepot.com/textSearch.do?uniqueSearchFlag=tr ue&Ntt=kraft+paper&x=41&y=19
PostPosted: Thu Oct 27, 2005 2:35 am
First name: Coe
Last Name: Franklin
City: Decatur
Wal-mart has craft paper,too. Probably cheaper, I`d say.
PostPosted: Thu Oct 27, 2005 2:51 am
Koa and Black Acacia. I am with John, Craft paper.
PostPosted: Thu Oct 27, 2005 3:20 am
Is kraft paper made to take the heat, or is the heat we're using not enough to be a problem? That's why I was thinking of using something along the lines of that baking paper.
PostPosted: Thu Oct 27, 2005 3:30 am
[QUOTE=letseatpaste] Is kraft paper made to take the heat, or is the heat we're using not enough to be a problem? That's why I was thinking of using something along the lines of that baking paper.[/QUOTE]
Kraft paper is fine at 300-400 dF I would be weary of bakers paper due to the parafin coating used as a release agent.
PostPosted: Thu Oct 27, 2005 3:35 am
   You guys are right on the brown paper. What I like about it is that it is celouse based and I havn't had any reactions whatever.
    You will get water staining but you get that anyway and that will sand right off. I use a working temp of 270 to 350 depending on the wood and the paper is fine. You only need about 28 inches and it will do the job well.
john
PostPosted: Thu Oct 27, 2005 11:17 am
Boiling point of water: 212 deg.F...
Burning point of paper: 451 deg.F (remember Bradbury's "Fahrenheit 451"?
